  1. Hi all,
    After some expirimenting (I had trouble with frameserving, TMPGenc stopped responding) I found out that direct stream copy solved my problem.
    Now... my question is: what's the difference between "direct stream copy" and "full processing mode" ?
    Anybody ?
    Cheers,
    Richard
  2. full-processing decompresses the data, applies whatever filters you want, then recompresses.
    direct stream copy just copies whatever frames you want without re-encoding. (you can cut frames w/o re-encoding for AVI)
  3. So... if I understand it correctly (don't flame me if I'm wrong) theoretically subtitling isn't possible, using direct stream copy ?
    Cheers,
    Richard
