Need help with AVerTV TV PVR card...can't record sound
Hi there.
I've recently installed a AVerTV Desktop TV PVR card on ym PC. I have it connected and have been able to capture whatever video I have running into it (DVD, VHS, DirecTV, etc).
But for some reason, I have been unable to record any sound. I can watch with sound, it just doesn't record.
My configuration is such that the audio line plugs to the Audio In, and there is a loop wire that goes from the "Audio Out" into the sound card in.
Still it, doesn't record the sound. Anyone have any pointers or tip for me to remedy?
Thanks in advance,
Quinn
email@directvcd.com
Open up the Volume controls either from the Tray or via Control Panel and make sure you have the correct input(s) selected for Recording. That may be the problem.
AverTV USB HD DVR or Hauppauge USB HD PVR
By gll99 in forum Capturing and VCRReplies: 34Last Post: 8th Jun 2015, 10:56 -
Hauppauge hd pvr sound issues with new graphics card
By Mitterhouse in forum Capturing and VCRReplies: 2Last Post: 27th Mar 2011, 18:26 -
I have a few questions regarding capturing with AVerTV HD PVR and a PS3.
By phenom97 in forum Capturing and VCRReplies: 2Last Post: 22nd Sep 2010, 09:02 -
Best Capture Card Under $150?? (AVerTV CaptureHD??)
By jenna12 in forum Capturing and VCRReplies: 7Last Post: 1st Apr 2010, 13:38 -
change hardware encoding options in AVerTV PVR M116 Plus
By mb508 in forum LinuxReplies: 0Last Post: 19th Sep 2007, 08:14
