I wondered if i could encode (or author, dont actually know which stage this comes in at) a normal xvid video into a dvd format which stretched to fit my widescreen tv but played normally on a normal tv???
If this is possible what settings should i use (preferably in tmpgenc)
Thanks in advance,
Michael Jones
Yep it is possible. Choose under Settings->Advanced->Source aspect ratio: 1:1 and under Video arrange method->Full screen(keep aspect ratio). Then choose under Settings->Video->Aspect ratio 16:9. (To unlock all the settings load the unlock template in the template extra folder or right click on the setting and choose unlock)
Author with a tool that support 16:9 anamorphic like dvd-lab. -
Cheers for the help mate... is their a prgram which supports anamorphic movies and allows you to insert DVD compliant SVCD (with the audio already converted) such as DVD Workshop (although cant use this specific program because it causes sync problems)...
I know its a bit jumbled but hopefully you'll get what i mean
Michael
Is it possible to re-edit a non-anamorphic dvd to anamorphic?
By Beautiful Alone in forum DVD RippingReplies: 45Last Post: 22nd Sep 2011, 09:00 -
Best way to convert 4:3/non-anamorphic DVDs to 16:9 anamorphic. HELP!!
By CoachSerpico in forum Video ConversionReplies: 9Last Post: 11th Feb 2010, 15:46 -
anamorphic or dv pal 16:9
By Fking in forum Newbie / General discussionsReplies: 4Last Post: 28th May 2008, 13:11 -
anamorphic or not anamorphic
By cd090580 in forum Video ConversionReplies: 3Last Post: 23rd Jun 2007, 12:48 -
Anamorphic --> 4:3 Ltbx?
By acs236 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 9th Jun 2007, 11:57
