i have downloaded a film in xvid but i have no sound when i encode using tmpgenc plus but when i play the film on win media player it is perfect i was told to use virtualdub mp3 freeze but dont know how to any help is very needed as im very new to all this
try this:
-click 'OPTIONS' on the top
-choose 'ENVIRONMENTAL SETTINGS'
-choose the'VFAPI PLUG-INS' top tab
-right click the 'DIRECTSHOW MULTIMEDIA FILE READER' and then higher the priority to 1 or 2 -
I also have this problem.
When I try to encode any file in TMPGEN that has the AC3 audio format then I end up with no sound. When encoding files with the MP3 audio format however it works fine. I have tried following the guide " Convert A DivX with AC3 To VCD" but this doesnt work for me. Ive also tried the reply by " honorarybrutha" but again no joy.
I have the AC3 codec installed so these files work fine through windows media player, but I really want to make them into VCDs. Can anyone help? Please?
Grantos -
Goldwave is great for creating a wav file from any .avi file, no matter the audio format. Just load in the avi then save. Use the resulting wav file as the audio source for your encoder.
"Art is making something out of nothing and selling it." - Frank Zappa -
Since I posted my problem I have tried again to encode the ac3 audio file and end up with sound. And this time it worked. I found that using a combination of both the "Convert A DivX with AC3 To VCD" guide and "honorarybrutha's" last post did indeed work.
One other thing bugging me is the poor quality (jerkyness) with the video after encoding. Is there any settings within TMPGEN that improve this?
Thanks.
Grantos -
More than likely a problem with frame rate.Originally Posted by Grantos
What frame rate is the original AVI? (Use file information in Virtualdub to check.)
Which template did you use in TMPGEnc for your encoding, Pal, NTSC or NTSC Film?"Art is making something out of nothing and selling it." - Frank Zappa -
another tip on ac3 audio is to install Odio Dekoda
http://www.moonlight.co.il/download/?dl=odiodekoda
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
Film capture issue - partial film frames on a video frame. Why?
By brassplyer in forum RestorationReplies: 14Last Post: 27th Apr 2010, 17:14 -
The Independent Film Channel - efficient film challenge - cash prizes
By minidv2dvd in forum Latest Video NewsReplies: 1Last Post: 23rd Oct 2009, 10:44 -
Telecine Machine for 8mm film super 8 film transfer to dvd
By igotregister in forum Capturing and VCRReplies: 5Last Post: 2nd Feb 2009, 16:50 -
My DVD Film backups are 'freezing up' near end of Film
By Artom in forum Newbie / General discussionsReplies: 5Last Post: 18th Jun 2007, 04:01
