  1. I have to get somee new codecs for my pc, so i can watch DivX , AVI, XviD and so on...... without getting blue collours on my screen. It would be great to look at an movie with the collours that is original for the movie.. .... and one more thing.... if i want to docode the movie to svcd or something.... i don’t weant to end up turning my tv upsidedown......so..... I want codecs that keep the correct collours and picture the right way when i watch it.... I have been lookin for codecs and looked at both guides and the forum.... but i did not find anything that was 100% helpful.
    Apr 2003
    poole england
    go to nemo.com and download build8 that will give u the codec
  3. Thanx for the tip..
    I have downloaded Nemo, i tryed to decode a film from Xvid to svcd, first I looked at the Xvid version of the movie, at first the screen was green, then I got a picture, but itt seemed that there was two movies playing at the same time. 50% time it was like that, and the rest it was ok…. Dunno if the problems are in the codec, or the movie….
  4. The Green part is normal with xvid, and if the problem with the two movies playing at once was only 50% of the time then it's from the movie.
    get someone else to try the movie on their computer.
  5. I have tryed more then one movie now… all Xvid… all were bad… Nemo has to be the problem….how can i delete it…. And where can I get a better codec????
    What program is best for decoding an Xvid/AVI to Svcd..... Name more then one.. TMPGE i know about... And not that found of....
    May 2003
    Greater Manchester,Uk
    Lol Jack_d, try this Xvid codec (latest binery one) at http://www.roeder.goe.net/~koepi/xvid.shtml
    As for another prog for encoding, try Panasonic Mpeg Encoder i find it works pretty good but it is slower than TMPGEnc.
    Let us know how it goes.
    Hope this helps
  7. i've been having the same problem as you guys.....I cleared that all up when i installed bsplayer. The player is fantastic...it cleans the images right up. it also helps if you install ffdshow. these two software can be found in the tools section. hope this helps!
  8. Now i have tryed to use TMPGE to decode an Xvid to vcd… and then play it on my dvd player… I got a black screen…. Not what I was hoping for…
    BSplayer is something I have had on my pc, but it didn’t work for me… but I think I have to try again….
    Thanx people….
