Hi,
I'm about to buy a new digital camcorder (MiniDV).
Mein Rechner ist ein P3-700 mit 384 MB Ram.
Will I be able to get the video to my PC with a firewire card or is it just to slow?
I know that editing the video will be very slow, but will I get the video to my PC without any quality loss?
Sorry for my bad english,
but thanks for any help
Marcus
Sure, You can do that.
Just download "DVIO" and stat to capture from your Firewire card.
You will not loss any quality.
It will work fine! I started on a P3 733Mhz and it worked fine. I also use a P2 266Mhz notebook computer to do some capturing and editing, but need to use an external firewire hard drive to make it work. Editing and conversion to mpeg will be slow. If you need more hard drive space, I would suggest you buy an external that connects with firewire. Not the fastest option, but it might help with the capturing. There are several FREE tools that you can use to transfer the video from DV camera to your PC. Just click on the tools button at the left of the page. I use DVio for most of my work, and then use EditStudio for my editing. http://www.puremotion.com for a free 30 day trial of Editstudio, get the trial of mpegXS too.
Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
Convert DVD to ca 700 MB avi using what?
By younso in forum DVD RippingReplies: 2Last Post: 9th Feb 2011, 18:57 -
Sony DV-700 hook-up to Mac
By bildix in forum MacReplies: 8Last Post: 3rd Dec 2010, 19:33 -
Needing a new camera under $700
By ingeborgdot in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 70Last Post: 7th Sep 2009, 15:11 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
700 MB or 4.1 GB
By lsutiger1001 in forum Newbie / General discussionsReplies: 1Last Post: 7th May 2008, 20:01
