  1. ok, just bought an ati tv wonder to make vcds and using the guide on the site, 'How to Capture using a ATI All In Wonder'. I capture fine and then when i play the video back (in windows media player) i only have the video. the video looks great but there's no audio. the audio isnt 'x' out in media player but its no there also.. any ideas or any help plzzz
    tia, Drew
    Jan 2001
    Vancouver/Portland
    Make sure you can confirm your captures ACTUALLY contains audio. You might not be even capturing the audio with your video. Double-check by going to "Volume Control" panel and select your correct audio component in the RECORDING properties.
  3. Make Sure you double click the tv channel and check audio to mute off.
