I don't know if anyone else has had this problem, but when I convert avi files to mpeg with tmpgenc and try to use the soften noise block feature, the feature almost never has any effect. I have only been able to get it to work once on a file with a framerate of 29.97 fps. The files I am currently working with are 23.976 fps. Does the framerate affect whether or not the soften noise block function has any effect? I don't know what I'm doing wrong, could someone give me some advice?
Thanks in advance.
well, I have to say that I am disappointed with Tmpeg because of this. I get block noise all the damn time. I have tried every different setting and template anyone has suggested. I have recently switched encoders to Panasonic's MPG encoder and since have not experienced ANY block noise at all. all oif my movies play flawlessly. It's a bit slower that Tmpeg but it is much better.
The problem is that I'm using a source file that doesn't have a high enough bitrate, so I'd like to try to get rid of the blocks that are present in the source file, but when I encode to mpeg. Anybody know why the soften noise block feature has no effect for me?
Hmm, i use an older version of tmpg and the block noise does work. although i never have much block noise to begin with. Of course i never set it too high (its default 35-40 for both).
and to the other poster who mentioned that he recieved no noise with the Panasonic, i find that amusing, because in my case it has been the opposite.
depending on what you use to capture and at what rate befroe encoding, this may help reduce your block noise to begin with. Maybe you are not capturing at a high enough rate and you have so much noise for the lowrate capture that the noise block appears to be not helping at all? -
I'm using a divx avi (I know, pretty low quality sometimes) which has the noise blocks in the source file. I tried converting one file that was the same way, and it seemed to work. Maybe you're right, the source file may just have too many bitrate shortages to begin with. I figured the soften noise block in tmpgenc was a way to fix that to a certain extent, but maybe I'm wrong. Thanks for your response, anyway.
remove noise and block.
By mathmax in forum RestorationReplies: 124Last Post: 21st Mar 2014, 15:51 -
Deleting or softening a "creaking" noise in recital audio in Audacity
By MLK3329 in forum Video ConversionReplies: 5Last Post: 9th Oct 2010, 15:41 -
Multi-colored block noise bug in Adobe Premiere - DV video
By tat2jr1 in forum EditingReplies: 0Last Post: 23rd Jan 2010, 02:20 -
Avisynth filters to remove mosquito noise without softening
By AlanHK in forum RestorationReplies: 8Last Post: 7th Jan 2010, 23:49 -
sony dcr-trv740 tape 'horizontal block shift' problem
By david101 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 13th Sep 2008, 22:42
