If I have two 700 Mb AVI files that I want to burn as SVCD, thats going to take up four cd's right??
Could i cut it down to two disks without messing up the quality???
I have a couple of questions about the files:
1) What kind of audio do the files have? Usually a two part avi has ac3 audio. Does yours?
2) How long are each file in minutes? Because the more time that you try to fit onto a svcd the more you have to reduce the bitrate of the video to make it fit. And A lower bitrate CAN cause you to have a lesser quality output video. -
I got the following from Gspot on File # 1
694 MB (or 711,612 KB or 728,690,688 bytes)
Video:
Length: 01:01:09 (91,722 fr)
x,y:640x352 (1.818:1) [~11:6]
Audio:
0x0055(MP3) ID'd as MPEG-1 Layer 3
Bitrate: 224 kb/s (112/ch x 2 ch) VBR LAME3.91
Fs:48000 Hz -
Sure I would try encoding each avi as a mpg. You might want to use an external audio encoder in TMPG because you will need to change the audio to 44100 hz for svcd. TMPG will do that for you but its not very good at it. And set the motion search precision to the highest possible setting. It will take longer but I think Its worth it.
I actually just tried to hammer it trough TMPG and ended with 1523 kb/s bitrate and i looked good....the sounds was good too. Thx for your help!
Best quality DVD output software for maintaining photo quality
By P_Erickson in forum Newbie / General discussionsReplies: 20Last Post: 21st Apr 2012, 22:30 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
3 AVIs to DVD low quality or medium quality to drive then DVDshrink?
By johnharlin in forum Video ConversionReplies: 5Last Post: 4th Apr 2009, 02:18 -
lower low quality online tv how to high quality :( :x
By gorry563 in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Feb 2009, 06:56 -
&fmt=18 does not give the same quality as playing by "high quality
By arminio in forum Video Streaming DownloadingReplies: 2Last Post: 9th Feb 2009, 18:33
