    Aug 2001
    Scotland
    give some more info - what are you capturing - what capture card, what codec.
    I had problems for a while with captured files playing at about half the speed - which caused jumping due to forced audio sync. This was when using lossless codecs for capture.
    I updated the card capture driver and now it is OK (however there is a noticeable slight speed up in appearance to the actual incoming video)
    When I capture direct with divx there is no problem.
    Have you tried different codecs etc?
    regards
    scattergun
  2. Hi guys, I'm new to this and sorry if it's a dumb question but I need help.
    When I capture my file, and try to play it back it plays at about double the speed that it should. Because of this the sound is out of sync too. I tried it capturing at 29.9 fps & 25 fps and exactly the same thing happened.
    Any help is appreciated, and again sorry if it sounds dumb.
    -James
