    Portland OR/Hita Japan
    I just got an archos jukebox multimedia. And have been trying to make a compatibly divx for it. so far ive gotten either the audio or video will play, but non at the same time. I have tried using ffmpegx, but when i use its mp3 audio, it plays messed up on it. anyone have a fix for this? i am wondering if there is a way to multiplex an avi files video, with a pre recorded mp3.
    Q
    "Good Luck 007"
    In Memory of Desmond Llewelyn
    ok, well i found my problem. I need an MP3 encoder codec. Can anyone help me find one? or someone who has one?
    Q
    "Good Luck 007"
  3. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    iTunes is free isn't it? That should give you an mp3 encoder. If not, I see you are running OSX. Since that is simply freeBSD, you should be able to find a whole host of mp3 utilities that you could port to X. Check the gnuDarwin web site for sources and a porting engine. After that I can't really help, I'm one of those stupid winderz users
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  4. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    i tunes will do mp3 encoding, just make sure you set the specs you want in the preferences.
    there are others, suggest visiting http://www.versiontracker.com/mp/new_search.m?productDB=MacOSX&mode=Quick&OS_Filter=ma...ch=mp3+encoder
    you can see the options avaliable.
    enjoy
    /galactica
    Thanks for the response, i should have been a lil more specific, i need an mp3 encoder for quicktime.
    Q
    "Good Luck 007"
    well, i got divx pro, and it works, but it only works when there is no audio, when theres audio, it only plays the audio. any help me there?
    Q
    "Good Luck 007"
