I just created 3 dvd's of the original star wars laserdisc set with my panny DMR-E50. I want to copy them to my hard drive and and somehow remove the main menu it created or get it to play the film automatically avoiding the menu.
How can I do this without interfering with the video once I re-burn the discs?
Lots of ways to defur this feline.
Since your data on your Panny disk isn't encrypted, all you really need do is to demux the VOBs and/or use a program that can author a disk using the VOBs. Me being me, I'd suggest using DVDLab 1.1, which can do either one.
It can do an awful lot more (and there are freeware solutions for what you want) but the upside is there is a fully-functional trial available, the program is only $79, it's easy to use and do what you want to do, and you may find you want to do authoring later with this, the best authoring program for the dollar out there."Like a knife, he cuts through life, like every day's his last" -- Mr. Kiss Kiss Bang Bang
Panasonic DMR-EZ48VK How do I get into its hidden setup menu (Service Menu)
By RS456 in forum DVD & Blu-ray RecordersReplies: 20Last Post: 14th Nov 2011, 01:50 -
dvd stuck in dvd player - best removal technique?
By ChaunceyK in forum Off topicReplies: 9Last Post: 22nd Mar 2010, 20:07 -
Panasonic DMR E50/E55 drive replacement
By zzucru in forum DVD & Blu-ray RecordersReplies: 3Last Post: 7th Oct 2008, 13:09 -
looking to replace a panasonic DMR -E50 any ideas?
By edmond in forum DVD & Blu-ray RecordersReplies: 4Last Post: 27th Oct 2007, 12:34 -
Pioneer 340 as replacement for Panny DMR-E80?
By LynnL in forum DVD & Blu-ray RecordersReplies: 0Last Post: 7th Jun 2007, 13:04
