Why not split an mpeg - does this constitute editing...
I have always used vcdcutter and don't notice any difference in the result - in fact I often find that the original mpegs won't play properly with media player, but the splits work fine.
I admit I haven't tried splitting the avi first do you think I should?
scattergun
I'm not Truman, but I'll try to answer your question anyway.
It is always preferable to do ALL editing in the AVI stage. However, cutting is usually ok, with a few caveats.
In my experience, I've never had any problems cutting standard MPEG-1 for VCDs (i.e., CBR MPEG-1).
However, many people here have spoken of problems with cutting MPEG-2 for SVCD (i.e., VBR MPEG-2) -- so I would probably encode the halves separate if possible.
Regards.
Michael Tam
w: Morsels of Evidence -
Do vcdcutter cut to B or P frames too?
Many MPEG editing tools wont do that, so the you can not point the frame exactly.
Actually MPEG "cutting" work by demultiplexing / multiplexing. You'll see the "out of synth" questions here often...
A safe and very comfortable method is to use the source range and encode in several parts (batch encoding).
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
