  1. Hi All,
    just thought i would let you know that i bought a new processor today. its an AMD XP BARTON 2500+! I already have a 2200+ but at £82-00 Inc VAT & delivery i couldn't resist. it is the retail version so they give me a HS & fan also! Get it from : http://www.scan.co.uk/products!
    i thought it would be interesting to compare the encoding speed of CCE from my 2500+ with that of the 2200+. I know the speed varies with the settings used but i will save the settings in dvd2svcd and use exactly the same parameters!
    I am also going to try to overclcock the processor a little, nothing too serious, perhaps increasing the voltage a little, but if i am luck i will get good stepping and hopefully be able to increase its speed to 2800+ or more without an increase in heat output!
    And the best thing about it all? if it doesn't like being overclocked much, or i dont notice a significant increase in encoding speed all i need to do is take it to a local computer exchange shop where they will give me the same price for it!!! isn;t that great?!? So, at the worst i will loose nothing! at the best i will gain a highly overclokable processor for very little extra money! YEAH!!!!
    i will post the encoding results in this forum when it arrives, should have it by the end of the week!
    1)Why Not Overclock a little?! speed 4 free!!!!
    2) If your question has anything to do with copying PS2/PC/XBox games, find a more appropriate website
    Aug 2002
    Behind the wheel of a R34
    I got 2 Opetron chips that im planning to use to replace this Dual 1.5 Xeon. If only my paycheck gives me $600 to use...
    Mar 2002
    Hawaii
    Won't you have to replace the motherboard as well? Did the Opterons even come out yet?
    Aug 2002
    the 600 are for the motherboard.
    go to newegg.com and type this in the search bar
    N82E16819103386
    Mar 2002
    Hawaii
    Do windows oses support the opteron?
    Aug 2002
    Havent tried XP but yeah. They should. Im running this in a leaked version of LongHorn...
    I think Win2003 can do it since its a server based application.
