I have the Indiana Jones movies and the Star Wars special edition VHS and I want to convert them to a digital format. I was thinking of going with CVD, since its almost like SVCD but with better bitrates. Does anyone have ideas as to the best capture settings or the best settings for encoding, or what formats to use?? thanks
Questions like this one always generate a LOT of debate, but since you're planning to make a CVD anyway, then the best resolution to capture at would 352x480. (NTSC) This resolution is extremely popular for VHS capture anyway as it will capture ALL of the video data available on a VHS source. (2 interlaced fileds of 352x240... or 352x480).
This capture resolution is hotly debated, but since CVD resolution is also 352x480 (NTSC) then no one should argue much about it on this particular thread. ...right, gang?
The format you use depends on your capture device. If it's an analog capture card, either capture using huffy or an MJPEG codec to AVI and encode to MPG with TMPEG or CCE.
If using TMPEG, load the AVI as a 4:3 source instead of a 1:1 VGA. Encode the film to CVD specs and burn. No deinterlacing is needed and it will look correct when played back on your standalone player.
Other capture devices let you capture to MPEG2 directly. IF this works for you at acceptable quality (rare) then cap it directly to MPG. If you're in a PAL area then substitute the PAL resolutions wherever you saw 352x480.
Good luck!
NitemareEven a broken clock is right twice a day. -
Not sure what card you use, but depending on this you may never get the quality you are looking for. I used to have a card that captured to AVI and it always looked like crap IMO. Blocky, grainy, just horrible.
Now I use a DVD card and s-video cords to capture straight to VOB. If you have a good VCR you will get a capture that's every bit as good as the original, and a clean source is the most important thing to start with.
You can then use DVD2AVI and TMPGenc to create CVD's that will look as sweet as a transfer from VHS can. -
i use showshifter program to capture vhs in high qualilty wmv2. then change the .wmv extension to .asf and encode in tmpgencode. I get excellent results everytime
Sharp VCR (or similar) S-VHS quality for best capture of my VHS tape?
By ruehl84 in forum Capturing and VCRReplies: 0Last Post: 19th Feb 2012, 16:52 -
What's new in capture cards for VHS capture?
By chowmein in forum Capturing and VCRReplies: 21Last Post: 29th Jul 2010, 09:03 -
Which $150 or under capture card for VHS/S-VHS -> computer?
By HDClown in forum Capturing and VCRReplies: 25Last Post: 16th Apr 2010, 23:16 -
VHS to DV capture: Component video vs. S-VHS
By vega12 in forum Capturing and VCRReplies: 8Last Post: 19th Feb 2009, 20:42 -
Capture device needed for old VHS or 8mm camcorder capture....What to get?
By thor911 in forum Capturing and VCRReplies: 11Last Post: 5th Oct 2007, 05:31
