hi this something i dont know, but its something ive just notived, when doin audio cd's using nero i always get the option for buffer underrun protection and it says its enabled when writing, but when i do a dvd disc i dont get the option and it doesn't say buffer underrun protection enabled when writing either
why is this? why can't it be used for both oviously it would be helpful.
thanks
click on choose recorder, then at the bottom of the window that opens, there is an options button, press that and the buffer underrun protection box is viewable and also the dvd high compatibility mode aswell.
this is on 5.5.10.7 upwards
dvd high compatibility mode was checked anyway what does that actualy do? then it says in brackets next to it (at least 1gb wil be written)
get smart doesnt work with DVD Fab
By shoesss in forum DVD RippingReplies: 6Last Post: 7th Nov 2008, 12:52 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
Samsung DVD-HR737 doesnt work with 1-16X DVDs
By bengt39 in forum DVD & Blu-ray RecordersReplies: 3Last Post: 16th Dec 2007, 12:27 -
Some audio doesnt work
By TheEmperor in forum AudioReplies: 2Last Post: 16th Aug 2007, 10:05 -
HELP! DVD Burning VOB files doesnt work
By liam0114 in forum Newbie / General discussionsReplies: 3Last Post: 5th Aug 2007, 18:35
