Whoever coined the phrase 'Takes the confusion out of buying a dvd writer' (refering to -/+ writers) wants shooting.
Im considering getting a multi writer and i am down to two drives, theres the NEC 1300A and then theres all these SONY drives, im leaning towards SONY but the problem is what are all these different versions all about?
How old is the SONY DWU-10A, does it have any problems, basically is it a good drive to buy and what prices are we talking about that makes this drive worth splashing out the cash for?
SONY should really stop flooding the market with drive after drive, they have more money than sense.
IF you take a look at your left, you will see DVD Writers section. You will find reviews of drives.. the NEC look to be a really bad choice since -R media dont work as expected.
How does HD Writer do it?
By OldNick in forum Authoring (DVD)Replies: 7Last Post: 11th Mar 2012, 20:57 -
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 02:06 -
DL DVD Writer?
By LiCal in forum DVD & Blu-ray WritersReplies: 4Last Post: 7th Nov 2007, 01:08 -
Dual Core vs Dual Processor
By kissvid in forum ComputerReplies: 59Last Post: 17th Jun 2007, 11:27
