I have just decrypted a dvd, i now have an iso file on my desktop, what do i use to burn it? nero? btw, i have been using nero to do a straight copy, it works fine, but i have to keep reading an image which takes 30 mins. i am trying to find a faster process![]()
use decrypter to burn it back ( mode, iso, write).
make sure it will fit one disc though.
thingimijig. -
musher70Originally Posted by musher70
Why do you feel you should use [File Mode] method rather than [ISO read/write mode]? I have done some extensive tests on the two methods and just wondered what evidence you might have to back up such a statement?
Thank You
Dd(;-{> Dd
Strength and Honor
www.dvd9to5.com
www.dvd9to5.com/forum/
"For every moment of truth there's confusion in life"
Black Sabbath/Ronnie James Dio -
"just wondered what evidence you might have to back up such a statement?"
Doesn't need evidence,
Common sense would tell you, that if you rip in file mode, you can test the rip & work with the files if you need to. -
The key is 'if need too.' If it's a DVD5 disc you can just rip the ISO image, and then burn the image.
Even if you want to edit the DVD it's still easier to rip an ISO image, then mount it with Deamon Tools. This way I have store several image files in one dir, vs. several VIDEO_TS folders. Given that many programs won't work unless the VIDEO_TS folder is in the root dir, that's another reason to rip jus the image file.
But to each his own. I prefer to store/save several image files to by 2nd HD and mout them as necessary. And if those images are less than 4.7GB I can just burn them as needed/desired.
Decrypted VOB playback pixelated
By SiDon in forum DVD RippingReplies: 2Last Post: 4th Jun 2010, 08:50 -
decrypted, converted .vob to .mpg but have no menus
By chgoguy in forum Video ConversionReplies: 6Last Post: 8th Aug 2009, 17:03 -
Decrypted DVD9 plays fine from harddrive, not when burned to DVD+R DL
By ndaher in forum DVD RippingReplies: 4Last Post: 7th Sep 2007, 15:35
