Quick question:
How many minutes of data can I fit onto an 80min (800Mb) CD-R using SVCD format?
Details (only the ones you need to know):
-29.97fps
-2400kbps CBR (Constant Birtate!) video stream
-224kbps Stereo, MPEG2 audio stream tooLAME
And don't go tell me to use the bitratecalc thing, because it doesn't work once you get below 70min of data (or something like that) per CD. I was messin around with it and the final bitrate doesn't change weather you have 5 minutes of data on a CD or 55. Screwed.
All I need is a measly 35min (but mandatory 224kbps stereo audio) of data on an 80min CD, with the highest quality available (but still keeping within SVCD standards).
thanks.
BTW, has anyone noticed anything weird when encoding with tooLAME? I use it, but there is one thing that I do not like. It adds static (white noise) to my audio stream, but luckily, it's quiet. But still, you can definitely notice it when listening to the original and then the compressed, not just because of compression, but you can hear white noise. I am using the latest tooLAME, 0.12h or something like that, and encoding 224kbps stereo.
AP Enterprises Ltd. -
Hey thanks Truman!
I gotta try that FitCD thing out for myself...
Use a bitrate calculator and choose either xVCD or xSVCD, the vcdhelp.com bitrate calculator will work fine if you choose xVCD. The bitrate is the bitrate...
svcd on windows 7 : Vob Size problem?
By kiwi76 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Jan 2010, 13:58 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10 -
question about how to remove simple software
By jimdagys in forum ComputerReplies: 2Last Post: 10th Apr 2008, 11:15 -
another simple question about FCE and iDVD... =)
By ednarophati in forum MacReplies: 1Last Post: 31st Jul 2007, 10:15
