I've heard conflicting opions as to whether XVID to MPEG 1 conversions should use a no compression .WAV as the audio source or not ?
I usually feed the XVID directly into TMPGenc and it seems to be ok other than a slight sync issue (nothing major).
Is this typical?
"Today is only yesterdays tomorrow"
Audio has nothing to do with what encoder is used for the video stream. If audio should be extracde first (or not) is entirely dependent on how the audio is encoded. So, it doesn't matter if it's DivX, XviD or anything, as these only deal with video. Possibly XviD encoded videos more often come interleaved with exotic audio streams, but again this is not "hard coded" into the XviD video compression.
However, since extraction and decoding of audio is simple and not that lengthy, I tend to always extract and decode audio to wav before encoding to mpeg1/2, possibly normalizing in the process.
/Mats
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
extract a matrice from an xvid avi file ? [SOLVED]
By vhelp in forum Newbie / General discussionsReplies: 12Last Post: 15th Nov 2011, 09:14 -
Extract Audio from XviD MPEG-4 video
By MI6 in forum AudioReplies: 2Last Post: 3rd Jan 2009, 05:58 -
cannot extract wav from AVI
By ecc in forum AudioReplies: 3Last Post: 22nd Jul 2008, 18:21 -
Extract audio to WAV using VirtualDubMod
By jimmalenko in forum User guidesReplies: 15Last Post: 14th Nov 2007, 02:42
