Well, i've searched the net a few hours now, and I cannot find out if the 4x datawrite DVDr's work on my sony...
If anyone knows please reply, looks like ppl have had different experiences with the 2x datawrite brands:
DVD +R
Datawrite - Errors at the end Speed 2.4x Cost £2.00
JVC - Errors at the end Speed 2.4x Cost £2.50
DVD -R
White Label - wouldnt finalise Speed 1x Cost £0.75
Bulkpaq GP - wouldnt recognise Speed 1x Cost £1.00
Datawrite - wouldnt recognise Speed 1x Cost £0.90
and someone said that all his datawrite brands worked 100%...
They work ok, but not @ 4x (Well, might work 4x with 1.0d firmware). I hava had only two of them for testing purpose.
With firmware 1.0f the burn started 4x but dropped to 2x after a while.
With firmware 2.0f the burn started 2x.
Didn't notice any playback problems with my Philips DVD player (but didn't have time to watch it all the way through). I will get more of these this week, so I will try writing 4x with different firmwares. -
I havent tryed the red version yet but tempted, I am using f version and have no problems using the datawrite yellows 1x or the grey 2x versions using recordnow dx that came with the drive there the ones I only buy now as reluctant to try anything else. The only problems I have sometimes when doing copy to copy they bomb out now and again at 95 percent, but may have found a way round that by not using the copy to copy in the recordnow menu use the add data method and select the files from you dvd-rom reader. Anyway I am more than happy with 2x datawrite grey discs 30mins done about 30 odd discs with them now.
sheppy
the red datawrite 4x are unreliable they are a no no they will put you off datawrite steer clear these are real coaster disks the yellows and greys are good for the money though
i have dru500a
I am having no probs with the reds in a 105, but I presume the Sony is a bit different. Shame really, cos <£1 a blank is quite good for 4x.
Will AVCHD-DVDR work on DL DVD?
By cheerful in forum Authoring (Blu-ray)Replies: 8Last Post: 14th Aug 2010, 23:54 -
How do I increase brightness/contrast on DVDR only have DVD to work with)
By sonicdeth in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2010, 12:44 -
DVD Unlock Codes for Philips DVDR 3506 and Sony DAV-FC9
By DanSF in forum Newbie / General discussionsReplies: 4Last Post: 29th Sep 2009, 03:13 -
Sony BDP-S350 problem with DVDR.
By blackhawk465 in forum DVD & Blu-ray PlayersReplies: 11Last Post: 1st Aug 2009, 15:57 -
Which DVD-R?? Datawrite??
By nos707 in forum MediaReplies: 7Last Post: 18th Sep 2008, 20:41
