can you tell me of the best way to rip dvd to vcd and svcd.by best i mean fastest tried some of the guides and they work but very slow at encoding.is it possable to do it with virtualdub? if so what setting do i use to encode it to vcd and svcd? or is there a guide to do this? if so where?i woukd like to use virtual dub because i can set it to do a list of files on its own and walk away from it. unless there is another program that can do this as well?
Vdub does not convert to mpeg, which is what you require and what TMPGEnc does. DVD2avi automates ripping and encoding, it requires TMPGEnc or another encoder to be pre-installed. Here's a guide: http://www.doom9.org/index.html?/mpg/d2a-svcd.htm
"Art is making something out of nothing and selling it." - Frank Zappa -
bottom line, there is no fast way. The faster your computer is, the faster it will encode. video encoding is a very intensive cpu hogging process. If you want quality, then it will take time.
I've heard that increaseing your CPU cache in TMpegnc will boost your encoding time. Not to sure about that, haven't tried it myself yet.
You say you want to use Vdub so you can give it a list of things to do then walk away. Do the same thing with TMPGenc. Give it a list of things to do then walk away. Granted, if you give it too long a list you'll need to stay a way for a WHILE, but it'll be well worth it.
Sometimes, ya just gotta.....umm, what's the word........FART???
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
