ihave an athlon 1.4
ddr ram
on a raid board
im wondering what frame rate should i be getting ..
i use flask for standard vcd s
i rip the dvd vob s to my hd and just encode them
i only get 17 ...to 18 frame rate
is that supposed to be normal???
Need more info. If you source is ripped DVD then your framerate is either 29.97fps or 23.976fps (if you live in Europe 25fps).
I assume you encode the VOBs as MPEG1/2 files? What program do you use, what settings/template do you us, what makes you think you're encoded file is 17~18fps?
Maybe I missunderstand you, what do you mean by 'frame rate'? -
i use flask
encoding pal movies
onto mpeg 1 for vcd , the reason i know what frames per second i m getting is because flask tell s you as it s encoding
but i am wondering what frame rate i should be getting
Please define 'frame rate'? I'm not sure what you mean? Also what frame per sec are you getting (for PAL should be 25fps).
I think the "frames per second while encoding" that you mentioned is the ENCODING frames per second. This is how fast the encoder is working for you
Your output in flask is limited to 23.976, 24, 25, 29.97 fps
so your output would have to be one of theses!!!
surely the out put frames ( the rate at which it s encoding ) depends upon the processor ??
for example a 1 and a half hr movie generally takes me ,on average 2 hrs to encode
how long does it take you lot?? -
muuuuuuuuuuuuuuuuuuuuuuuch longer (using duron 750 w/ 256 pc100 RAM)
-Elchknie
.srt and frame rate
By Mercurialol in forum SubtitleReplies: 5Last Post: 4th Dec 2010, 04:45 -
Bit Rate And Frame Rate
By bharathi_n_r in forum Video ConversionReplies: 2Last Post: 30th Nov 2007, 06:48 -
Frame rate conversion
By Alexstarfire in forum Video ConversionReplies: 35Last Post: 22nd Aug 2007, 14:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 11:15 -
nero frame rate
By bong1 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 30th Jul 2007, 16:50
