I got a firewire cable (4-pin to 4-pin) for my new Sony TRV 22 about a month ago. It was one from Best Buy, I think 30 dollars or so, but I cant find it on the website to show you. Anyway. i am now having rouble capturing. I am using Adobe Premiere 6.0, but I do not think it is a camera, computer or Adobe problem. It used to capture perfectly, but now when I capture the audio and video both skip and just all together mess up. Is this a cable problem? Any help appreciated, and maybe some advice on a new cable for me?
You may want to capture in DV to another software program, just to rule out the cable. And of course, double check your connections.
Hello. -
Well, I failed to mention this, but my friend has tried the cable on HIS camcorder on HIS computer on Ulead Video 7.0 (I believe) and has aquired the same results.
If your problem is following your cable, looks like you have it narrowed down.
Hello.
No Audio In Encore/Bad Aspect Ratio/Bad Files/Bad ISO/Bad Everything
By koberulz in forum Newbie / General discussionsReplies: 35Last Post: 24th Jan 2010, 05:48 -
bad quality after capturing by FireWire
By Medes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Oct 2008, 08:08 -
Bad motherboard or bad CPU?
By videohalp in forum ComputerReplies: 11Last Post: 9th Jul 2008, 11:07 -
Bad encoding? Bad installation
By lo-q in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2007, 20:45 -
Motion Blur/Bad Quality when capturing uncompressed
By Ezekiel 4:12 in forum Capturing and VCRReplies: 4Last Post: 15th Jul 2007, 02:44
