  1. I've been using DVDMaestro to author some DVDs, but the DVDs I burn do not display the time elapsed on my DVD player, it just says play.
    Can someone suggest what I need to do with Maestro to sort this out.
    Thanks in advance,
    Ben
  2. Член BJ_M's Avatar
    Jul 2002
    Canada
    there is a problem with the time stamps on your assets ..
    you can encode with CCE or main concept which can place the correct time stamps or on the timecode line in maestro switch it from asset based to 0 based (or was it the other way ? ) , anyway that sometimes works but can cause other problems ..
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    this is not as unusal as you might think -- i just watched "Run Lola Run" (Lola rennt) and it had the same problem plus the FF and REV was screwed up
