i'm creating menu and chapters with this tool http://www.dvdit.com. but how to use disc that i created with dvdid on home DVDplayer.if anyone knows,tell me pls!!!!i use this tool to create DVD with amaizing menus and buttons and plaing that DVD on PC,but i want to use on regular DVD player.thanks!!!!!!!!
I don't use this program but from their website I found:
"Output options - Once the project settings are entered, you have a choice of creating a DVD disc (using a CD-R or DVD-R), a DVD folder on your hard drive, or a DLT tape for replication. Each of these is set on a separate menu option, and brings up a dialog box specific to the output operation you have selected."
So it sounds like you can output directly to a DVDR (ie. burn from within the program) or generate a VIDEO_TS folder on your HD and then burn that to DVDR (eg. Nero, DVD Decrypter, etc). If you have a VIDEO_TS folder click to the left under "Author" to find quides on how to burn this folder to a DVDR.
Question: do you have a DVDR drive or a CDR drive? Not sure from your post. If CDR you can not (directly) keep all the buttons and hotkeys from your menu.
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 11:17 -
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 13:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 15:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 22:43
