ive joined a few vcd.s tmpeg, but were the join is it goes green and the the sound go's offso can any one recomend any other program that will do
thanks
You could try joining them with Nero Burning Rom. You just need to start up the Video CD wizard, and then drag both the files into the side bit that has the open space in the order that you want them, and then make sure you right click on each of the files, and click properties. Then where it says pause after track, just type 0 for the seconds (for both files). Then click apply and then burn the CD. The few times I have joined VCD's using this method, there wasn't anything like what you say. There would be many other programs to do it with, but this is the one I've used.
thanks for that but if i do that i an't going to be able to burn it to cd, it would be way to big for a cd, and plus i want to join them so i can encode it then burn it to dvd, but thanks anyway
Have you tried Tmpgenc? Just use the merge/cut option in the mpeg tools menu.
I use a very small (less than 100k) program called "FileMerger" that will let you join anything together, even multiple files
And yes, I have tried it with AVI's and it works with no problems, as I think it does no checking of what its joining, just literally joins A to B, it will quite easily join A-B-C-D and so on, the checking is entirely down to you
I use it to join MP3's together so that I can edit any parts that are mixed with previous/next MP3's. A snag with ripping 'net radio stations. The software just isn't good enough to guess accurately enough where it starts and end, no matter how much you tweak the settings -
Did a download.com and google search for "FileMerger join avi" (and other variations) but couldn't find anything. Could you please provide a link to this program, I'd like to check it out.
Thanks in advance. -
i found it strate away but hers a link anywayOriginally Posted by Vejita-sama
http://home.planet.nl/~doesw008/filemerger.html -
has anyone got any other ideas on this coz irealy need to find a reyable program to join vcd's
Joing mkv files when they are not splitted at keyframes
By wateshadon in forum EditingReplies: 1Last Post: 11th Jul 2011, 14:01 -
How do I joing 2 files
By wan2no in forum ComputerReplies: 4Last Post: 17th May 2008, 00:46 -
Joing two dvds?
By Castor troy in forum DVD RippingReplies: 1Last Post: 10th Feb 2008, 18:21 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
