Results 1 to 10 of 10
    Aug 2002
    England
    Hi
    I got this program to re-encode DIVX/XVIDAVI to mpg.
    I use mainconcept standalone encoder but it doesn't keep the aspect ratio. I've been led to believe this program does.
    Can anyone give me a quick simple guide to using this program?
    I just want to open the avi then encode it to VCD Pal.
    Nothing else.
    At the moment I'm being a bit of a muppet and I can't even see how to insert the video.
    Cheers
    Fozzee
  2. use tmpgenc instead its far simpler more flexible and its free for encoding Vcd and its probably better than mainactor.
    The electronic components of the power part adopted a lot of Rubycons.
    Aug 2002
    England
    This program uses the main concept encoder which is a lot faster than TMPGenc and does not require the audio on divx/avi to be stripped first.
    So my request stands any help appreciated.
    I also understand Video Studio 6 uses mainconcept encoder??
    Does this program keep aspect ratio??
    Cheers
    Fozzee
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
    yes it does - but main concept Main Actor has a pretty complete guide that comes with it though already including tutorials .. there is also a forum just for this product on the main concept site ..
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    It can't add black borders if your source is widescreen(keep the original aspect ratio). Then you must use avisynth or virtualdub first and then frameserve to mainconcept.
    Aug 2002
    England
    Think I'll just go back to extracting the audio to wav and using TMPGEnc.
    I was looking for a hassle free way which would be there if Maincncept standalone kept the aspect ratio on VCD.
    Strangely it keeps it if u encode to mpeg1.
    Fozzee
  7. Член BJ_M's Avatar
    Jul 2002
    Canada
    he is using mainactor 5, not main concept standalone encoder ..
    main actor is a NLE app that is somewhat like a video factory/ ulead type of program
    http://www.mainconcept.com/mainactor_v5.shtml
    on this page is a ton of users guides and tutorials for mainactor 5
    manual is here http://downloads.mainconcept.com/mactren.zip (20megs)
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    okey, I meant the standalone encoder not the mainactor editing tool. Mainactor should probably fix it.
  9. Член BJ_M's Avatar
    Jul 2002
    Canada
    anyone tried out mainactor 5 or the other new mainconcept apps?
    post your reviews in a new thread ..
    Aug 2002
    England
    That's what I thought you meant.
    I am trying MainActor5 right now.
    Fozzee
