  1. Member scottb721's Avatar
    Oct 2002
    Australia
    The starting image is 1173 x 800 but when I open it in Nero C.D. it takes up less than 1/4 of the Insert page.
    Does it lose quality when I drag it out to fill the Insert page ?
    I have an Epson Photo 830 printer.
    It prints photos great but when ever I print out DVD covers they come out crap. I'm using HP "semi-gloss everyday photo paper" but no matter what settings I choose I get the black bleeding into the other colours.
    Perhaps I might have to try some Epson paper.
  2. Member Faustus's Avatar
    Apr 2002
    Dallas, TX
    I'd suggest trying out CoverXP and see if that does what you need.
    Apr 2002
    The State of Frustration
    I use SureThing. The backgrounds you can add to your labels beats Nero hands down in muy opinion.
    Hello.
  4. Member scottb721's Avatar
    Oct 2002
    Australia
    As long as one of then has a templatefor a plastic DVD case I'll be happy.
    Thanks.
    Apr 2002
    Absolutely.
    Hello.
  6. Far too goddamn old now EddyH's Avatar
    Jan 2003
    Soul sucking suburbia! But a different part since I last logged on.
    Nero editor looks pretty but ultimately is
    It ended up printing at about 100dpi the couple times i tried it.. you're as well to make yourself a big ass image in paintbrush (or paintshop/photoshop etc if you can "afford" it) - just use the old system of notepad/pen pad/eyes to transfer the titles and details - then print it at custom size (4.75 inches on a side, ~12.25cm) or drop into word and resize.
    Best of all is using MS Publisher or similar programs as they're hella easy to make designs for such things with, once you've got the size down (basically get a preprinted one and grab a ruler). Even fairly decent results with a few gradient fills, bit of text, a couple auto shapes and a photo/scan/drawing or a carefully chosen clipart.
    bundled stuff usually =
    -= She sez there's ants in the carpet, dirty little monsters! =-
    Back after a long time away, mainly because I now need to start making up vidcapped DVDRs for work and I haven't a clue where to start any more!
  7. Member scottb721's Avatar
    Oct 2002
    Australia
    It turns out the semi-gloss HP paper I'm using is shit. I printed the same picture twice, first on HP then Epson paper. The print on the Epson paper came out shmick. Could be one reason, apart from the obvious, why Epson recommend using their own papers.
