Should I bother using 2-pass VBR for xVCDs or is it just a waste of time?
And what bitrates should I use? (i want to fit about 60 min on a cd)
Results 1 to 10 of 10
what resolution do you use?
xvcd is a general name for unstandart vcd, so what is the x for ?
bitrate? resolution? both?
the extra bitrate will only go so far for a certin resolution,
sometimes its better to a lower resolution to get a better picture
at a certin bitrate.
write down the resolution you intend to use and you will get a better
answer...
in general, you will have to use an
everage bitrate of about 1600 to fit 60 min of film on a cdHELL AINT A BAD PLACE TO BE -
Sorry i didn't tell you what resolution I use. I use PAL vcd resolution, 352*288.
I routinely make PAL XVCDs from PAL SVCDs using TMPEG with 2 PassVBR (3000max/2500av/1800min.kbps 480x576 MPEG-1).
The filesize and quality are very close to the original.
However, your player may not be able to handle the non standard MPEG-1 resolution and/or high bitrate. Best to re-encode a short section and burn to a CD-RW. -
i whould go with vbr
you will see much difference with vbr with high bitrate.
but you can make your own little test and find out for yourself
if its better in your eyes.HELL AINT A BAD PLACE TO BE -
Thanks for your replies. I know you save diskspace by using vbr, how much?
Originally Posted by hamman
Here's a rough rule of thumb from my own experience:
The VBR average can be about 2/3 of the CBR setting for similar quality. So for VCD about 800 avg. and SVCD about 1700 avg. will give good results.Typically, VBR will fit a movie on 2 disks in SVCD while CBR needs 3."Art is making something out of nothing and selling it." - Frank Zappa -
Take a look at:
https://www.videohelp.com/forum/viewtopic.php?t=157572&highlight=vbr+cbr
it's a good past dicussion about CBR vs. VBR, and how both encoding methods work. VBR encodes do not really 'save space' they better to think of VBR as a way to 'get more video on each CDR without losing quaility.'
MPEG2 VBR to CBR
By dl_sledding in forum Video ConversionReplies: 0Last Post: 26th May 2010, 11:27 -
cbr to vbr
By dynamix1 in forum AudioReplies: 1Last Post: 17th Mar 2009, 14:12 -
CBR vs VBR
By prl in forum Newbie / General discussionsReplies: 5Last Post: 11th Jan 2009, 18:48 -
question about vbr v/s cbr and 2 pass vbr
By perfection in forum Newbie / General discussionsReplies: 4Last Post: 14th Dec 2008, 03:55 -
VBR or CBR?
By dizzie in forum ffmpegX general discussionReplies: 1Last Post: 29th Jun 2007, 14:28
