i captured frommy ati 9000 128 DDR ViVo card using composite and audio left and right from a DV-CAM! but the picture which was recorded was grey and it dropped frames like HELL! i used adobe premiere and chose 640x??? for quality! can someone tell me what an suitable quality is when i capture from a DV cam not using a firewire??? would be appreciated!!!
greetz
PS: im using
-1600+
-512 DDR infineon
-100 Gigs
-ATI 9000 ViVo 128 DDR
kazaa rules...
Well, for starters, using the firewire cable is not "capturing" but instead merely transferring a file from the digital camera to the PC vai the firewire cable.
If you're using an ATI card with a digital camera, are you sure you're not re-capturing and thus wasting the benefits of having a digital camera?I'm not online anymore. Ask BALDRICK, LORDSMURF or SATSTORM for help. PM's are ignored. -
well, i know firewire just tranfers the file but i didnt know how to say it when i capture the movie with adobe premiere via composite cable... i just want to have the movie on the DV-cam on my pc and thus tried it via composite which really sucked!
i wanted to know how to receive good quality using composite...
greetzkazaa rules... -
i know that!!!
but if i havent a DV cam how can i capture my VHS tapes with the best quality? could u tell me the connections?
kazaa rules...
High Quality Capturing with Little Frame Loss in VirtualDub
By monsoon01 in forum User guidesReplies: 65Last Post: 18th May 2013, 22:33 -
Stop Motion Animation Frame by Frame Capturing
By Fary4u in forum Capturing and VCRReplies: 9Last Post: 5th Jan 2012, 16:49 -
bad quality after capturing by FireWire
By Medes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 1st Oct 2008, 07:08 -
why does my ATI VIVO quality suck so bad
By bacobits in forum Capturing and VCRReplies: 3Last Post: 2nd Jan 2008, 20:22 -
Motion Blur/Bad Quality when capturing uncompressed
By Ezekiel 4:12 in forum Capturing and VCRReplies: 4Last Post: 15th Jul 2007, 01:44
