Trying to convert my VCDs to DVDR. Easy enough, but how do I extract my entrypoints from the \VCD\ENTRIES.VCD file? I don't want to have to watch the whole video again and figure out the break points![]()
Don't start analyzing the entries-file.
Better use the "rip" method of VCDwizard (see link below, using the method "don't ripp streams" will only deliver the data of the first track (without ISO-data and without movies)).
Then you've got all entries in VCDwizard.
When you follow the link to "lkVCDimager", you can download 'lkVCDxRip' which does the same but without using VCDwizard. Instead it "rebuilds" an XML-file, in which all entries are listed.
Overlapping subtitle timings for multiple entries onscreen?
By viewpoint in forum SubtitleReplies: 1Last Post: 30th Aug 2009, 21:22 -
Why TWO M-JPEG codec entries?
By terrypin in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2009, 17:38 -
Mass Deleting Registry Entries
By mysts in forum ComputerReplies: 8Last Post: 28th Apr 2008, 09:57 -
Number of possible chapter entry points: 1 - WTF?
By DRP in forum VCDEasy GeneralReplies: 20Last Post: 20th Mar 2008, 19:50
