On the advise of the forum I got DVD Menu Studio and it looks really nice. But I've got a small problem trying to make subpictures. The online help file:
C:\Program Files\DVDMenu\Help\indexdvd.htm
"When the background is ready, simply switch into a Subpicture mode (Usually Sub 1 or Sub 2) and draw the subpicture.. ..and draw an underline with Rectangle tool for each menu item we want."
Ok, simple enough. But I can't figure out how to do this! The manual makes it sound/look like all you do is select subpicture1, draw a rectangle, and the subpic is created. But when I try to do this I select the background image.
I can only make subpics by selecting a layer (another bmp or text) and then choosing "copy to subpic." I know there's another/easier way to do this.
What I'd like to do is take a background (either still image or a screen capture from a motion menu). Highlight where I want to buttons to go. Then export to author in DVD Maesto.
Isn't there some way to create a subpic based on the background you imported?
I've noticed that the "copy to subpic" button only copies to subpicture 1, which is handy if you're only planning on using one subpic. Selecting the image or text you want to use as subpic 2-4 I've just copied (using the command), then selected which subpic I want it placed in and pasted it there. You can't create the actual button areas for export to Maestro IIRC. You still have to create the button areas from within Maestro. You can use Menu Studio to create and export the color scheme for the subpics which is handy.
Originally Posted by Vejita-sama
DVD Menu bug in Pinnacle Studio 11
By P_Cherry in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2010, 08:22 -
One subpicture overlay across menu cells? - DVDLab Pro
By nostrum in forum Authoring (DVD)Replies: 0Last Post: 8th Feb 2010, 10:36 -
Multiple subpicture streams in menu for different color schemes?
By Alex_ander in forum Authoring (DVD)Replies: 5Last Post: 12th Jul 2008, 02:53 -
DVD Lab "the subpicture of menu 1 is created from copy of external fil
By BeachNut in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2008, 08:05 -
TmpgEnc Menu Confusion
By marioval in forum Authoring (DVD)Replies: 6Last Post: 12th Oct 2007, 06:23
