I have an mpeg (svcd) file that plays in german.
The file title says it is also english.
How do i switch languages?
Since this is a SVCD (MPEG2) I assume that it was made by multiplexing/muxing 3 streams together: m2v (video) mp2 (audio - german), mp2 (audio - english).
To be honest I don't know anyway to select audio streams from the MPEG (save to demux, then remux with only the english track). However, if you burn it as a SVCD you can switch languages by hitting the "audio" button on your remote (or software DVD player, eg. PowerDVD). -
O.K
My PowerDVD program doesnt recognize the format for some reason.
Also this file is over 700 mb so I have to buy 800mb disks.
Anyway the part about the muxed files is what I was after.
I will try to demux and split the file.
Thanks -
Well an 80min CDR holds 800MB of (S)VCD data. PowerDVD should be able to see the different audio streams in a SVCD (not just the plain MPEG file). Still de-mux and re-mux should do it (I assume
Vejita.
Are you saying that the 80min. 700mb cd/rs hold 800mb of data.
I have Nero and I tried to use the overburn option and it said the media was too small for the file.
I must be missing a setting. -
Be sure to select SVCD in Nero
www.dvdrhelp.com/nerosvcd
And read this about svcd/vcd data capacities
https://www.videohelp.com/forum/userguides/135642.php
RCA VCR - change language without remote?
By TrackingError in forum Newbie / General discussionsReplies: 7Last Post: 2nd Feb 2022, 11:15 -
change audio language
By natty in forum Newbie / General discussionsReplies: 14Last Post: 1st Sep 2011, 07:07 -
Change m4v subtitle track language
By Kurgan71 in forum SubtitleReplies: 2Last Post: 19th May 2011, 09:42 -
HP Laptop, change language?
By Seasonal in forum ComputerReplies: 6Last Post: 18th Mar 2011, 08:58 -
Change audio language
By mew1033 in forum Authoring (DVD)Replies: 7Last Post: 24th Dec 2009, 05:31
