Been having a problem burning VCD/SVCD lately. Been doing what I normally do: burn VCD/SVCD using Roxio EasyCD Creator, Record NowDX or VCDEasy, same media as usual, but all of a sudden, none of my VCD/SVCD play on my stand-alone DVD player. All the files are on the disc too.
I made sure my Disc is closed and all video is in correct format, but nothing works, on either of my 2 burners.
The only difference I notice is that the VCD/SVCDs that I burned before last week (and work fine) have a darker color area around the rim, where I think the free space is, the ones that I made recently and do not work have a barely noticable color difference around the rim.
What is the problem?
Any help would be greatly appreciated since now none of the VCD/SVCD I burn work.
Windows XP
Older internal CD burner
Sony DRX 500 ULX DVD burner
Did you change media??
Try burning in the Sony and see if the problem goes away. Could be the aser getting weak or a change of media.
I have noticed that some brands of media have a more pronounced difference in color between burned and unburned areas than other brands of media. On some brands I can barely see the difference but they work OK too.
Good Luck -
Been trying with my burners including the Sony, no luck. I have no idea what happened, I was getting great VCD/SVCDs with both burners last week.
Increasing color depth and sampling for color correction
By poisondeathray in forum Newbie / General discussionsReplies: 17Last Post: 17th Oct 2009, 10:06 -
Converting a color video to black and white apart from one color. Possible?
By SteveLock in forum EditingReplies: 7Last Post: 23rd Feb 2009, 09:04 -
[color=blue]video oediting software for ASUS Eee PC (white ones)[/color]
By helpmepls in forum Newbie / General discussionsReplies: 1Last Post: 6th Feb 2009, 08:53 -
Color shift in ffmpeg X - ffmpegX native color space and gamma?
By rbot1980 in forum ffmpegX general discussionReplies: 0Last Post: 2nd Feb 2009, 22:16 -
[color=red]how do you play region 2 dvds on this setup[/color]
By j821977 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2008, 15:58
