I am capturing using composite, i would use S-Video for a better picture, but when i try to capture through this i just get a black and white image.. can anyone explain or remedy this ?? does this only happen with PAL ??
ta
" Your gonna need a bigger boat .... "
hi Athlon,
I'm not from PAL land, but here in NTSC land, when you go from RCA to
S-Video, you have to use PREVIEW instead. And, if you set to PREVIEW,
you have to reset the colors.
A quick way around this is to pratice step each time you setup your capture
card..
* After pressing "P" for PREVIEW (vdub)
* press "S" key and then press ok or <RETURN> key, and that's it.
You'll see the colors re-adjust. When that happens, you are ready. Just
remember to always practice this, and you'll be alright - k?
Good luck, from
-vhelp -
thanx for the help dude, but that didnt work. I know about setting the source of the video, but I'm not going from RCA to S-Video, I'm going from S-Video to S-Video !!
there must be someone in the UK that has done this ....
Grey video panes on Virtualdub
By kamepi_chan in forum EditingReplies: 24Last Post: 24th Oct 2021, 04:18 -
Samsung LCD 32" grey picture
By @RNOLD in forum DVB / IPTVReplies: 0Last Post: 4th Mar 2012, 19:37 -
Virtualdub grey line on right side of video?
By Snorklex in forum Video ConversionReplies: 5Last Post: 27th Sep 2010, 06:49 -
[DV issue] Odd fields bitmapped in grey (and no picture)..?
By Gew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Aug 2009, 11:56 -
Converting to FLV results in jumpy, grey 'solarized' video
By snoogly in forum ffmpegX general discussionReplies: 1Last Post: 31st May 2009, 18:46
