Hiya
I am having huge probs with audio being out of sync, I have been through this forum and tried to turn PBC off and also press the audio twice to audio 2, then back to audio 1, it still doesnt seem to work.
I am testing them on the centropy releases of xmen and matrix reloaded.
They already came in a bin and cue combo.
I also have another svcd, roadkill, same probs with that too, what do you suggest I do, they are all in sync on the pc?
dont burn with nero step 1!
download and burn svcd with vcdeasy
turn offpbc option in vcdeasy.
burn away to your hearts content but chapters and some other functions wont work.
ALso turn off PBC on the tosh.
Or if none of this works burn only VCD these work fine with all menus etc.
you can extract the mpeg info from bin and cue files by mounting the image with daemon tools.Corned beef is now made to a higher standard than at any time in history.
Heya
Ive tried all the above, also tried teh vcd header trick,
it makes no difference with vcdeasy, still same audio outta sync
With the vcd header trick, i get the toshiba background with just sound, nothing else.
To convert to vcd, does this not comprise quality and takes a long long time to do? -
This problem exists on the SD220e also. If you look through this forum, you will see there is another thread on this topic for the SD220e:
https://www.videohelp.com/forum/viewtopic.php?t=154033
The good news is that I have found a solution for the SD220e (see details in the other thread), and that I have had reports from SD 210e owners that my solution works on this player also.
Basically, I have produced a modified version of VCDImager, which is used by VCDEasy to produce the SVCD. So far all reports have been encouraging.
So get yourself down to http://www.billh.demon.co.uk and follow the Video Editing links to the download page, and give it a try.
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Which one is better? Samsung D392 (mini-DV), Toshiba P10, Toshiba H20...
By renavspainatal in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 5th Nov 2009, 09:59 -
Videos in sync on pc, out of sync on DVD player
By DVantrease in forum Video ConversionReplies: 3Last Post: 2nd Sep 2009, 05:08 -
MPG with A/V sync to AVI with horrible A/V sync?
By RedPenguin in forum Video ConversionReplies: 92Last Post: 23rd Aug 2009, 17:17 -
Does Toshiba HD-A2 play SVCD's?
By desertfox in forum DVD & Blu-ray PlayersReplies: 3Last Post: 20th Aug 2007, 10:40
