I followed THIS tutorial on exporting a menu in DVD Menu Studio for Maestro. It works fine in Power DVD, but on my Apex-1100W the menu is almost a puzzle of the orginal menu in horizontal pieces.
Can anyone explain to me what caused this?
Also how do I get the menu to loop? Now it starts the movie once the menu sound has ended.
Could it be because i have 4:3 for my menu in DVD Maestro instead of 16x9? But my video seems to play fine as 4:3... any idea?
or maybe it was because I repatch the headers to 480 horizontal of my SVCD. perhaps I shouldn't have repatch one of the VOB's. Has anyone had this problem before?
What did you use to repatch the headers? (you shouldn't repatch the menu vob to 480)
I think i did patch the menu. I'll fix that and hopefully it will be alright.
Also, can there be different resolution video on the same DVD with DVD Maestro, because I wanted to put an intro movie at 720x480 if I could? Otherwise I would have to turn it into a SVCD and patch it. -
Supported DVD resolutions are 720x480, 352x480 and 352x240 (NTSC). 480x480 is not a supported resolution and not all players will play 480x480 header patched MPEGs. It sounds like there's a good possibility that your standalone player will not.
You can have titles with different resolutions on the same DVD.
Menus are normally 704x480 or 720x480 4:3 (do a forum search for why menus are often 4:3 even for 16:9 movies)
There's no need to encode to SVCD then patch, in fact that's asking for trouble. If you don't want to encode at D1 (720x480) then encode at 1/2 D1 (352x480). But the SVCD header patch trick DOES NOT WORK on all players, I understand that your source is SVCD (it appears) so you don't want to have to re-encode. But for all future projects it's much easier if you stick to a DVD supported resolution.
Multiavchd menu messed up
By jaydev2005 in forum Authoring (Blu-ray)Replies: 3Last Post: 21st Jul 2011, 16:23 -
DVD Menu bug in Pinnacle Studio 11
By P_Cherry in forum Newbie / General discussionsReplies: 6Last Post: 11th Dec 2010, 09:22 -
Pinnacle Studio - Multilevel DVD Menu
By donpedro in forum User guidesReplies: 6Last Post: 5th Sep 2010, 09:16 -
How To create new dvd's with menu's from existing ones from standalone unit
By bidelman in forum Authoring (DVD)Replies: 1Last Post: 6th Oct 2009, 17:01 -
DVD With standalone Menu HELP !
By rockonvidtrade in forum Authoring (DVD)Replies: 1Last Post: 11th Dec 2008, 13:51
