any one can tell me the best advanced setting for the MPEG1 VCD and MPEG1 XVCD . My DVD player doesn't support SVCD.
Hi ssv you a ready have MPEG1 VCD setting you could play around with advanced setting as for XVCD you need to bump up the bitrate 2000 to 2600 depend on DVD Player.
As for I haven't done any XVCD I wait for DVD-R to come on cost so I get one for now it most lee VCD and sometime SVCD.
There How To on my web site.
Just click on the HowTo Use Button
http://shs-tv.m0ss.com/ -
I have not found a setting on this card yet, in MPEG1 that I like, I only record using the MPEG2 settings I did under the advance settings for a SVCD.
Best I found so far for MPEG1 and still not happy with
352x240
2520 Constant bitrate(above setting at 5000)
throttle 0.070
audio 224
sharpness 1.00 or .50 (which ever you prefer)
Good Luck!! -
On 2001-09-20 18:09:02, thxkid wrote: I only record using the MPEG2 settings I did under the advance settings for a SVCD.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
thxkid - what settings are you using for SVCD? I've been trying to find SVCD settings that will allow me to save 45-50mins PAL on one SVCD but the picture quality doesn't seem very good.Would appreciate any help ....
wintv pvr usb2 in linux
By diablo in forum Capturing and VCRReplies: 0Last Post: 10th Sep 2011, 08:43 -
better unit than my old wintv pvr usb2
By diablo in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2011, 09:52 -
Hauppauge WinTV-PVR 250
By thatsgame1 in forum Newbie / General discussionsReplies: 5Last Post: 22nd Jun 2011, 06:54 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 10:39 -
Considering Hauppauge WinTV PVR 350...
By chewie8008 in forum Capturing and VCRReplies: 9Last Post: 2nd Oct 2007, 17:20
