This is realy weird cause it just started happening. Never had this problem before, but now it does the same thing on EVERY mpeg2 that I try to cut.
Using TMGEnc version 2.56.39.143 (just installed it as a new installation trying to fix problem). Ok, here the prob....
When it cuts the mpeg2, the last minute or so of the mpeg has no sound? Since the next file starts where the sound was lost (even though the start is the stop of the other file), it would suggest that TMGEnc is running past the stop point only for the video and not the audio.
Any experience with this? Any advice?
Thanx
Results 1 to 1 of 1
Cutting MTS: splitter problem
By cheerful in forum EditingReplies: 3Last Post: 6th Jun 2012, 20:26 -
TMPEnc Authoring Works 4 Problem with input AC3 Audio (5.1 channels)!!!
By JackyWang in forum Authoring (DVD)Replies: 10Last Post: 22nd Jun 2011, 11:46 -
Little problem-Cutting Scenes-Ideas?
By n3ur0 in forum Newbie / General discussionsReplies: 1Last Post: 17th Mar 2010, 09:44 -
Problem with TMPEnc DVD Author 3
By ebadillab in forum Authoring (DVD)Replies: 11Last Post: 28th Jul 2009, 07:23 -
Problem with TMPEnc
By Technophobe in forum Video ConversionReplies: 3Last Post: 28th Jul 2007, 17:44
