I have a simple still menu made from a jpeg background and a jpeg subpicture, with two buttons linked to two movies.
When I test navigation, everything works fine, but when I compile, the menu does not work in either PowerDVD or my standalone player. I.e. the buttons are not active when I glide the mouse over them in PowerDVD, and the remote buttons don't select them in the standalone.
The vobs play fine if accessed directly, and if I connect "First Play" directly to the first movie, that works. But even then, if I jump back to the menu while the movie is playing, the menu still doesn't work.
Anyone know what's wrong with my menu? Thanks.
Euro
Thanks BJ_M. That was it. I had disabled all user actions under menu properties. Funny, I was following the Maestro guide at doom9.org, which suggests deactivating everything for the main menu. So I did that without really thinking about it, and then forgot about it!
Simple Menu Creation
By Nanorip in forum Authoring (DVD)Replies: 0Last Post: 23rd Nov 2010, 23:36 -
How can I create this very simple menu with Multiavchd?
By alc112 in forum Authoring (Blu-ray)Replies: 2Last Post: 12th Jul 2010, 13:26 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
Help! DVD Maestro RealTime preview. Cinemaster not working.
By IJM in forum Authoring (DVD)Replies: 10Last Post: 1st Jan 2009, 03:22 -
Simple DVD Menu
By Burner2009 in forum Authoring (DVD)Replies: 5Last Post: 21st Nov 2008, 13:47
