help
ive been using recordnow for quite a while now no problems at all on win 98se
i upgraded to win xp and since then no good disc's
i have installed the nimo codec pack same as on win 98 but i cant seem to solve the prob
im using the same discs as always ive even tried to copy a disc i made while on win 98 but i get an error message when i try to play back on my computer
"windows cannot read from the disc it could be using a format not recognised by windows"
any ideas please im stuck
as a last resort can anyone suggest another program so i can write video_ts vob filed to a disc
We all started somewhere don't be affraid to ask
I've been using recordnow max for quite some time now on win xp pro and haven't had any problems at all. when you switch from win98 to xp, did you do a complete install (reformat entire drive), or did you just do an upgrade? I would suggest doing a complete install whenever upgrading operating systems to avoid problems.
Echo the above..
Recordnow max v4.5 on 3 pc's now running xp pro with no problems.
I used to be a die hard Nero fan, but got fed up with bug fix updates every second week, used RMN for ages now and stable with no updates.
Could it be your DMA settings or ASPI layer causing the problem, as xp dosnt have an ASPI layer from a standard install (see tools section for a fix) or the DMA settings in the device manager are set to PIO and not DMA.
Hope it helps ! -
hi there
re: orbital517
yes i did a full format and complete install ive also instaled sp1
re:fatboy
after an hour of searching i did enable DMA but im going to the tools menu now to get the fix for aspi
will let you both know how it goes shame to loose a good prog like recordnow
THANKS TO ALL FOR YOUR HELPWe all started somewhere don't be affraid to ask
prob joining VOBs; also sync prob with another movie
By spiritgumm in forum EditingReplies: 5Last Post: 19th Jun 2010, 10:32 -
A hardware prob, but what?
By ahhaa in forum ComputerReplies: 3Last Post: 22nd Sep 2009, 22:00 -
Wireless prob?
By Immortal25 in forum ComputerReplies: 4Last Post: 3rd Jun 2009, 08:55 -
gc prob
By Mr anderson in forum ComputerReplies: 6Last Post: 10th Sep 2007, 06:33 -
MPEG DV prob
By mainegate in forum ffmpegX general discussionReplies: 0Last Post: 24th Aug 2007, 18:01
