How do I connect my DMR-E30 to my TIVO set-up? Replacing my VCR.
Is should be fairly easy...
Me, I have a ReplayTV, and it sends video out of all the outputs at the same time (coaxial/RF, composite, s-video & component). You should be able to have one output go to your TV and the second go to your DVD recorder.
What I've done in my own setup is I picked up a SIMA SVS-4D which allows for 4 a/v inputs (svhs & composite in/out with digital & optical audio). As well as the 4 inputs, this switcher has 2 outputs (1 stream goes to the TV and the second goes out to you E-30). This switcher is auto switching/sensing, supports signal conversion (Composite to S-Video and back), and sends both video streams out at the same time (acting as a switcher as well as a splitter without adding any noticable noise). I picked this box up new on ebay for $125...it should be pretty easy to find. -
Pretty simple
Cable/Satellite A/V-Out--------> A/V-In TiVo A/V-Out------->A/V-In DMRE30 A/V-Out------>TV
You can use Coax, or the RCA jacks (or S-Video with the RCA Audio jacks). Best to use the S-Video whenever available as it will give you the best results.Cendyne/Pioneer 105 & 104 with a Dazzle* Hollywood DV-Bridge.
How to set correc IR (black level in panasonic dmr e55 and es15)
By mammo1789 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 13th Nov 2011, 10:42 -
Need to Remove Logo for a set time at a set place.
By Ensign in forum EditingReplies: 3Last Post: 11th Sep 2009, 16:39 -
x264, set quantizer to 10 and vary keyinterval to reach set target bitrate?
By frifox in forum Video ConversionReplies: 6Last Post: 20th Feb 2009, 16:59 -
panasonic dmr E30 compatibility
By jimakros in forum DVD & Blu-ray RecordersReplies: 5Last Post: 22nd Dec 2008, 13:19 -
Panasonic DMR-EZ27 Chip set?
By Deter in forum DVD & Blu-ray RecordersReplies: 5Last Post: 17th Sep 2008, 18:26
