ive downloaded a avi file but it will only play in virtualdub wont play in media player, how do i get it to play in media file
make sure you have the proper codecs installed ie divx and xvid
is there any error message that pops up when you try to play it....
or is there just no sound or picture?? -
download 'Gspot' its a tool that will tell you what codecs you need to play the vid and if you have them installed.....have you tried to play the video in any other player besides wmp??
cheers for that i'll give it a try & no i haven't tried it with any other prog besides virtualdub
Also, try looking at it with AVICodec, its not as over-whelming as GSpot and will tell you exactly what codec it needs
Try looking at ACEs codec pack, Nemo has a couple of quirks, but then again, I use bits from both of them, so I can't comment on either !
What MediaPlayer you using ??
I have some files that I can generate with an MPEG Encoder that MS MediaPlayer moans it can't play, but just ignore that error, and it will try to play it anyway, and majority of the time still plays it, even though it says it can't find a codec for that movie
Have a look at The Core Media Player, its not as bloated as MS MediaPlayer, and does just the same, and frequently plays stuff that MS MediaPlayer can't or won't play
Personally, I use both of them, if one won't play something I'm checking, then the other will
H.264 to AVI wont play in Quicktime
By kerr1586 in forum Newbie / General discussionsReplies: 3Last Post: 6th Jul 2011, 10:49 -
AVI with DTS wont play - can I convert?
By snadge in forum AudioReplies: 4Last Post: 29th Jul 2009, 09:41 -
data avi .hdtv.avi-fqm.wont play on set top recrder
By xbill in forum Newbie / General discussionsReplies: 3Last Post: 15th Jul 2009, 14:55 -
AVI wont play on standalone player, need to convert to what
By haubmi in forum Video ConversionReplies: 13Last Post: 10th Mar 2009, 13:58 -
WMP 11 XP avi wont play anymore
By axlefoley in forum Newbie / General discussionsReplies: 6Last Post: 28th Feb 2008, 01:39
