I'm running tmpgenc 2.58.44 and am in the process of converting some vcd's to dvd--the only thing is that when i run ssrc through tmpgenc to re-encode the audio, it crashes back to the desktop with no error messages or anything. I'm mystified. What could be the problem here? It has worked flawlessly on my other vcd's produced in the exact same manner?? Ideas?
Use an external application to resample the audio, then select that audiofile when encoding/muxing the clip.
yep i would use vdub
load it in vdub, select full processing in auido tab then conversion to 48,000 (might want to click high quality)
then save wav or avi should do the trick
Dazzle DVC 100 PROBLEM A valid input Signal has not been detected, HELP!
By Leon Smith in forum Capturing and VCRReplies: 5Last Post: 7th Nov 2011, 15:14 -
Good Up-converting DVD Player under $100
By wulf109 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 8th May 2011, 12:02 -
New Sanyo CA-100, need converting advice
By Blue407 in forum Video ConversionReplies: 1Last Post: 2nd Dec 2010, 03:30 -
Dazzle Digital Video Creator 100 (DVC 100)
By Rockin Rayzor in forum Newbie / General discussionsReplies: 3Last Post: 7th Nov 2008, 17:08 -
Problem with capping on my comp with WinDV and advc-100
By MikeMGMVE in forum Capturing and VCRReplies: 3Last Post: 2nd Oct 2008, 14:19
