Stoopid question time.
When I play the ripped vob files on my PC, the quality is great, but after using DVD2AVI and encoding with TMPGenc, with various setting suggestions from this forum, I still get lots of pixelation and blocks. Any way to make the encoded file same size as vob files to keep quality? I'm not an expert at this, but would assume if a 4GB movie is made into a 1GB mpg, it obviously cannot have the same quality??
I have seen lots of posts where ppl are trying to fit movie on 1 or 2 cds. Is it possible to get a better quality VCD by creating a copy that would take 4-5 vcds? If so, what settings should I use on TMPGenc to create the mpg?
Is it possible I have a bad codec?
I appreciate your suggestions to help me until I get a DVD burner (Soon I hope ! !).![]()
Try using templates of KVCD.
You can increase the videobitrate and have high quality vcd.
I have high quality vcd on 1 cd.
http://www.kvcd.net
making a good quality avi from ts, vob etc
By pooksahib in forum Video ConversionReplies: 8Last Post: 11th Sep 2011, 09:41 -
Making a high quality dvd of tutorials
By jeff dachowski in forum Newbie / General discussionsReplies: 20Last Post: 16th Jul 2011, 10:06 -
Really struggling making a high quality MPG from dvd on hard drive
By Yarko1967 in forum DVD RippingReplies: 29Last Post: 15th Apr 2011, 10:39 -
Making a VCD to send to the Philippines
By StrikerZERO in forum Authoring (VCD/SVCD)Replies: 17Last Post: 7th Dec 2010, 10:11 -
Making VCD Copy
By audiophile in forum Authoring (VCD/SVCD)Replies: 5Last Post: 18th Sep 2007, 08:20
