does anyone know what causes stream writing error in tmpgenc, i tried merging 6 mpg files but the program says STREAM WRITING ERROR, is there a way for me to merge these files because i already merge them before but there are some video gap so i decided to repeat the process.
Did you check your hard drive for enough space for the file?, have you checked it for errors?
A Full drive is the only time I have seen stream writing errors from tmpgenc.
Good Luck -
Had the same problem today, it was a result of the folder I was trying to write to being read-only
Make sure you set the permissions correctly on your folder!
Merging MPEG2 stream with its AC3 audio... or converting MKV to MPEG2
By cwt in forum Video ConversionReplies: 2Last Post: 5th May 2010, 15:18 -
Error in writing a YUV frame
By krao in forum Newbie / General discussionsReplies: 11Last Post: 1st Sep 2009, 11:47 -
DVD writing error
By nathy85 in forum Newbie / General discussionsReplies: 3Last Post: 23rd Nov 2007, 18:00 -
Error writing to media
By minepup in forum DVD & Blu-ray WritersReplies: 2Last Post: 21st Jul 2007, 08:28 -
Error burning .mpg files to DL disk
By Anonymous4374945 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd May 2007, 08:11
