I was following THIS tutorial and it says the start and final time of the video and audio should be 00:00:00:00. But shouldn't the end time be the actual end time? Well, the end time as it is now has the audio shorter than the video by 10 or so seconds depending on the clip. Could that be because SSRC in TMPGEnc didn't encode it right?
So, my questions are:
1. Are the start and end times of the audio and video suppose to be 00:00:00:00?
2. Why would the audio be 10 or so seconds shorter than the video?
3. Also, how quick are the transistions between clips when playing a movie because if it's instantanious I am going to edit the start times of some of the clips to eliminate the couple second overlap between clips.
Thanks in advance![]()
1. Start offset have to be 00:00:00:00.
2. Audio very often, almost alwys shorter, than video, but it makes no matter.
3. it's about 2 sec.
Audio length do not tally with video
By shans in forum Video ConversionReplies: 4Last Post: 7th Apr 2011, 11:11 -
Feature Length Video Compression for DVD
By grebanahs in forum MacReplies: 4Last Post: 18th Sep 2010, 03:51 -
Padding Audio to match Video Length with FFMPEG?
By boyer in forum Video ConversionReplies: 0Last Post: 31st May 2010, 10:13 -
Video 2X the length of audio after demux
By pchan in forum EditingReplies: 6Last Post: 18th Sep 2007, 22:51 -
Audio/Video Length Adjustment Script
By sweetfreek in forum Video ConversionReplies: 8Last Post: 1st Jun 2007, 23:19
