I am about to burn my first movie with the production version (I had tried the trial versions before, successfully.)
When I go to burn the movie, after clicking Make Disk, and Customize (I want to set it at 7000KBPS) Media type only shows PAL, and is greyed out. My defaults are set to NTSC. As well, audio type, and audio frequency are greyed out. (This is all very different from the trial version)
After setting it to 7000 kbps, and clicking OK, it gives me an error of "The settings you have chosen do not match the current disk format", and it forces me to choose the default template. (That is, it asks if I want to use the default template because of the error. If I click no, it goes back to the screen to select settings, most of which are greyed out. So, I click Yes, to use the default template.)
When I tell it to make a DVD dirctory, it wants to encode the files. It shouldn't need to, as they are already in DVD mpeg files, created from Premier 6.5 (The trial did not re-encode. I am guessing it wants to re-encode because my mpegs are at 7000, and I am guessing the default is 8000, so it wants to re-encode. And of course, it won't let me change it (Circular reference here)
By the way, I have applied the 1.3 patch, after installing from the 1.0 CD.
Any suggestions?
Results 1 to 1 of 1
Roger
ways to determine the bitrate of your dvd to xvid or h264 encodes
By codemaster in forum DVD RippingReplies: 2Last Post: 21st Sep 2011, 22:25 -
Mac Software that Encodes like a DVD Recorder
By Gypsy898 in forum MacReplies: 4Last Post: 13th Aug 2009, 22:31 -
Encodes to DVD turn up choppy
By architeuthis in forum ffmpegX general discussionReplies: 3Last Post: 22nd Feb 2009, 20:46 -
tape to dvd am I using the better options
By pantsdavies in forum Authoring (DVD)Replies: 1Last Post: 6th Nov 2007, 12:32 -
Audio sync consistently off on some dvd rip encodes
By carmat06 in forum DVD RippingReplies: 1Last Post: 25th Aug 2007, 20:07
