  1. The link to download The Avisynth BMP loaded on this page https://www.videohelp.com/forum/userguides/99389.php is kinda down Someone else has an available file online?
    I'm trying to convert a BMP to a video clip and got the script from this site:
    LoadPlugin("MPEG2DEC.dll")
    AudioDub(mpeg2source("C:matrixmatrix.d2v"),
    WAVSource("C:rescue.wav")).
    BilinearResize(448,404,0,0,720,576).AddBorders(16, 80,16,92)
    clip1=Trim(0,999).FadeOut(100)
    clip2=Trim(1000,0).Reverse.FadeOut(100).Reverse
    LoadPlugin("Avisynth BMP Loader.dll")
    BlankClip(250,100,100,"YUY2",25,1,44100,true,true, $000000)
    pic=AvisynthBMP_Loader("C:Pics","smile.bmp").
    BilinearResize(448,404).AddBorders(16,80,16,92).Re verse.
    FadeOut(100).Reverse.FadeOut(100)
    UnalignedSplice(clip1,pic,clip2)
    what is the d2v file?
    Also, what are the things I need to have?
    - The wave file (in this case: rescue.wav)
    - The bitmap file (in this case smile.bmp)
    Do I need a video file or is this automatically created?
    I just want to have this bitmap to a video file that's all without any insertion to any clips. Much like a stand-alone video file with nothing but the bitmap file.
    Any feedback is appreciated
    Feb 2001
    Berlin, Germany
    BMP_Loader comes with the DVD2SVCD package or download the single DLL here (up again)
    The script above is an example only. To convert a single image to a video clip it is as easy as that:
    LoadPlugin("Avisynth_BMP_Loader.dll")
    # template: define the framecount, framesize, colorspace, framerate
    # and audio properties of the clip
    # the framesize should not be smaller than the image size, otherwise
    # Avisynth may crash
    # replace all values below with the ones you need
    BlankClip(250,140,142,"YUY2",25,1,44100,true,true,$000000)
    # load the still image, replace path and filename with the real ones
    AvisynthBMP_Loader("C:\","yourimage.bmp")
    # resize if necessary
    BilinearResize( x, y)
    More powerfull is the Imagesequence plugin, that is available for Avisynth 2.0 and 2.5.
    # load the plugin
    LoadPlugin("imagesequence.dll")
    # open the still image
    ImageSequence("c:\yourimage.bmp",0, 249, 25)
    From Avisynth 2.51 RC2 the internal ImageReader filter replaces all plugins.
    ImageReader("c:\yourimage.bmp",0, 249, 25)
